Sunroof repair, not the usual one - Printable Version
+---- Thread: Sunroof repair, not the usual one (/sunroof-repair-not-the-usual-one.html)
Sunroof repair, not the usual one - MikeD914 - 11-23-2008
While raising my roof a while back I heard a pop/snap and the roof just fell back down and the arms retracked all the way back. Then, of course, I tried working the switch back and forth a few time, duh....Nothing....
I did a search for the typical gear repair and started taking things apart to see what I had. I found the plastic tube piece just off the motor was separated, not sure if it is suposed to be. And by working the switch, the motor had pulled the cable back into the fender compartment and now it wont go forward, only back.
Does anyone know what I'm dealing with here?
I took a couple of pics but can't seem to upload, and they're not posted anywhere on the net for a link... <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" />
TIA,
Mike D.
Ok, I posted a couple pics over on the bird board... <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
http://forums.pelicanparts.com/showthread....610#post4320610
Sunroof repair, not the usual one - DaveN - 11-23-2008
That picture paints a bads story. That plastic bit has snapped, you shouldn't see the cable inside. I assume now it is binding and not operating.
Sunroof repair, not the usual one - S_Cal968 - 11-25-2008
I've had mine retract the cable as seen in the pic. I had to manually re-position it and re-index the lifters. If one of the micro-switches works intermittently there's always the possibility of the cable over-extending.
p.s. I'll have to keep my eyes peeled next time I'm in SC, I'm out there quiet often...
Sunroof repair, not the usual one - Lim Yong - 10-29-2010
Anybody fixed this problem? My motor and cable works fine. But the tube extends when I
try opening the roof so it won't go up. When I close the the tube returns back to the motor.
