Lower engine cover panel
Guten Tag! The previous owner of my car removed the lower engine cover, for ease of lower engine access. I've never had the opportunity to drive the car with the part installed, and wondered what the consensus is, reinstall or stow? If installed I would expect a bit more aerodynamic drag at high speeds, and road splash contamination of the lower engine bay, but what about effects on engine operating temps, noise levels, etc?? I searched the forum regarding thesubject but did not score any hits.
As always, thanks in advance for the advice <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" /> ................
1994 Midnight Blue 968 Coupe
"Speed provides the one genuinely modern pleasure."
-Huxley
I would have thought that the cover would have assisted in the aero drag department - so to not have it there would upset the airflow and lower the car speed.
In general, I have not found it that much of a pain to remove and re-install.
If you are talking about the batwing (front apron), I have been told that it will reduce engine temps as the airflow is different with it off. I don't have one on mine and have been trying to find a reasonably priced one, but they don't seem to exist. You can buy them new through Porsche for $250-$300.
2005 Acura RL
2004 Toyota Sequoia
all of the lower panels REDUCE drag as well as promote better cooling
Thanks for info. I'll re-install this at next op.......and the brake cooling ducts I found stashed under the carpet in back, seems someone was a bit lazy and gaffed the re-install.
<img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
-Huxley
PS.......Sorry, I screwed up the verbage mid paragraph on my first post, I meant to state "If uninstalled.........................bla,bla,bla"
<img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
-Huxley
no worries - a lot of mechanics leave that stuff off for exactly the reason you cited - the car works better with them on though
08-14-2025, 10:12 PM
