Lens gap adjustment [taillight to bumper cover]
Well...I got ever so slightly rear ended yesterday. I pulled over and the other driver didn't...it was a love tap +
I noticed this morning that the gap between drivers side taillight and the bumper cover is a few mm larger than the passenger side gap. I took the rear light out thinking it possibly got loose but it wasn't the case. It seems the oval in the bumper cover has warped ever so slightly to create a larger gap for one side. Thoughts or methods I could employ to "adjust the gap" in the garage? Thank you.
Stay safe.
Foam tape on the bottom of the lens where it sits inside the bumper cover should do the trick
Quote:Foam tape on the bottom of the lens where it sits inside the bumper cover should do the trick
Sounds like a great workaround...thank you!  Will let y'all know how it goes.
Stay safe.
03-22-2023, 06:13 PM
Last Post by Uber968
03-21-2016, 12:40 AM
