03-20-2008, 08:37 PM
I apologize in advance for the length of this post...
Like many others, the firewall on my 95 coupe flexes when the clutch pedal is depressed. It does not appear that the firewall has actually cracked...yet.
A search of the forum indicates that some have remedied this problem by welding a doubler or reinforcement plate to the firewall, while others have installed a brace between the fender well or strut tower and the firewall.
Would it be possible to bolt a reinforcement plate to the firewall?
For anyone who has done the weld repair:
Did you weld the reinforcement plate on the front (engine) side of the firewall, or the back side of the firewall?
I presume welding will damage the paint on the firewall, and that proper repair of the paint requires removal of the clutch master cylinder, brake master cylinder and vacuum booster, and all hoses, tubes, wiring etc. in the area around the clutch master cylinder – is that correct?
Would anyone be willing to send or post photographs of their weld repair?
Separately, my car requires considerable effort to disengage and engage the clutch. I test drove three other 968’s before buying mine last year, and my car seems to have a heavier clutch than the other three cars I drove.
I understand that friction in the clutch mechanism can result from problems with the release fork bearings and lack of lubrication on the splined drive shaft, and I plan to have a repair shop determine whether those might be problems on my car.
My car has ~78,000 mi. I don’t have complete maintenance records, but there is no documentation to indicate that the clutch has been replaced. Sachs manufactures pressure plates in two different ranges of clamping force: 2300-2500 lb, and 3100-3300 lb.
Is there a way to determine which pressure plate – 2xxx lb, or 3xxx lb – was installed on my car when it was manufactured?
Do any of you have a 2xxx lb pressure plate and, if so, do you find it adequate for street driving?
Thanks in advance.
Joe
Thanks in advance.
Joe
Joe
1995 968 Coupe
Guards Red/Black
