Threads: 77
I did this in my car, but my remote uses the small 12volt batteries that seem to be common now. If your remote isn't that old check the battery it could be a 12 volt. I hardwired 12 volt into it, and bought an extra central lock button and wired it into the remote then put it into and extra hole in the center console.
Threads: 77
[quote name='flash' post='52018' date='May 7 2008, 09:03 AM']ok - i'm interested in this - i'd love to get rid of the remotes in my car, or at least hide them (though i question how effective they would be in any location i would place them)
i seem to remember a while back that somebody had done this in their visor
i'll see if i can find it[/quote]
Mine seems to work fine and you could really add it anywhere you want, as long as you have enough wire. I put my remote under the dash behind the radio and it has plent of range. I think part of that is the power source is probably a little more powerfull then the 12 volt battery it normally has. I could get the pin outs I used on the extra central lock button if somone wants, the red light even lights up when I press the button. In the garage remote itself I just soldered the wires from the switch into the circuit board on the remote. I could also grab a shot of that if someone wanted.
Threads: 77
[quote name='rxter' post='52027' date='May 7 2008, 02:39 PM']Pictures please, if you can, would be very helpful. This sounds like a great idea and an ideal location for hte button. I've almost lost the damned thing a couple of times in tight turns. Grabbed it as it was sliding off the visor.[/quote]
I used my old switch as it was getting worn and didn't quite resemble the key anymore and got a new one. The garage door is the one all the way on the right.
I have this tucked in behind the radio, but you could put it wherever.
The inside of the remote, which you can get an Lowes, it really universal for most doors. Red is positive, Black is negative. Then for the switch, the Purple/Black wire is on the right, and White/Red on the left. I soldered all these wires in.
Then on the switch side I ran the chassis ground directly into the top left post and then a ground out of it to the remote. The top right post is White/Red, and the Purple/Black is directly under the ground. This also results in the central lock switch I used lighting up the red LED in the switch when you hit the button..
Threads: 77
I has a slight brown hue to it, I think that is from being a Cabriolet and the sun beating down on it. It's easy to get to that switch, remove the ash tray, pull out the cubbie/clock, then unscrew the 4 screws that hold that panel on. I just did that to grab the pics, it's only takes a minute or so to get under that panel.
(This post was last modified: 05-07-2008, 04:49 PM by
banditsc.)
