Tail light wiring harness
Does anyone know if the tail light wiring harness with fog light will also fit a 968 that originally came without the rear fog light?
The wiring harness for 968 without rear fog light is no longer available, hence wondering if the one with fog light will cause any issues...
Any advice will be appreciated!
Thanks!
I am scratching my brain to figure out why you would need a fog light behind you?
So the car following you can see better in foggy situations of course...silly question.
Rear fog lights are compulsory in EU countries, so nearly all US imports have to have one connected (providing there is wiring and a blank space in the rear light cluster) or the new one installed. The same may be applicable in Singapore where I understand Chuaed968 is based.
just fit the harness and leave the bulb out if you dont want the fog light
Without fog 951 631 235 00
with fog 951 631 234 00 $250
There is no legal need in Singapore for cars to have fog lights, in fact you get pulled over for having them installed!
I was wondering if i could use the wiring harness that comes with fog light and simply leave the bulb out. As per Waylander, i suppose this is possible then.. thanks all!
Last Post by lbpesq
04-16-2025, 12:42 PM
Last Post by LES
10-07-2018, 06:52 PM
Last Post by archemist
09-03-2018, 06:26 AM
Last Post by robbgerard
02-03-2018, 11:46 PM
