03-25-2007, 01:40 AM
Hi All
Ok so now I have put my car back together after a month. I was so relieved after working so hard do the clutch right.
I took it off the stands and got in to feel the clutch peddle and found it near the floor! I could pull it up so that the spring sets it in the “up” position but it just pops back down to about 1.5” off the floor.
I really worked slow and steady to make sure that everything was right, the fork is engaged to the tabs on the throughout bearing and the slave cylinder rod is in the ball socket. Everything looked right when I buttoned it up.
The only thing I noticed is that I can feel some wiggle when I grab the ball end of the fork like the slave cylinder is not extending the way it should. Could the slave cylinder be pushed to far back into itself and stick there? Also I bled the slave cylinder and tryed to adjust the peddle but after that things were about the same.
Any thoughts?
BTW, I did a search on this subject and found some interesting points and one that referred to the wiggle at the ball end of the fork but didn’t see any resolution.
Thanks for any help
Steve
Any thoughts?
Thanks for any help
Steve
