Clutch shims (on release bearing/PP)
On my mom's 968, the clutch pedal engagement point has always been very low to the floor. I figured too many, or too few, shims were used on the release bearing / pressure plate during the last clutch job. I tried adjusting the clutch pedal where it connects to the clutch master cylinder but it wouldn't let me adjust it enough. Not even close to enough.
I took out the clutch today to see what's going on. Apparently clutch kits come with 2 shims. I found both shims installed, and they were put on the back of the pressure plate. I figure these shims could be left out, or even put on the front side of the pressure plate. I know these shims are used to offset the engagement point of the clutch (right?), so I wanted to know others' experiences with this. I really want to get this right!
TIA
Arash - '95 968 - '93 968
and the best one: '84 944!
the clutch engagement point is almost certainly a bleeding thing - it can be a REAL pain to bleed - the reservoir needs to be jiggled to keep fluid in the clutch portion as you bleed it with the power bleeder and then also with the finishing manual bleeding - the car should also be level, and not "nose in the air" to facilitate this
i do not remember there being any shims at all, and this is the first i have heard of it
[quote name='flash' post='40749' date='Sep 4 2007, 06:02 AM']the clutch engagement point is almost certainly a bleeding thing - it can be a REAL pain to bleed - the reservoir needs to be jiggled to keep fluid in the clutch portion as you bleed it with the power bleeder and then also with the finishing manual bleeding - the car should also be level, and not "nose in the air" to facilitate this
i do not remember there being any shims at all, and this is the first i have heard of it[/quote]
Hey Bob!
There are 2 shims, and usually both are used in order to eliminate play between the TOB and the PP. Everyone I have spoken with who has done a clutch job said they saw the 2 shims on the rear side of the PP, and they all had low pedal engagement. My own 968 has a perfect engagement point, right around halfway down. I wish I could see how the shims are configured on that car.
The fluid has already been bled, and every other behavior and characteristic of the clutch is fine, so I believe the system is free of air.
I wanted to take the flywheel and PP to a machine shop today to get resurfaced, but I can't get the flipping TOB off the PP. Tips, anyone?!?!
ok - now i remember the "shims" - they go between the TOB and the tangs of the PP
i'm still betting on bleeding - we just did hydraulics on ron's car, and it fought us every inch - turned out that a tiny leak in the blue line was allowing air back into the system
[quote name='FRporscheman' post='40764' date='Sep 4 2007, 10:29 PM']I wish I could see how the shims are configured on that car.[/quote]
If the shims on that car are in the same location, I think you should be able to see them through the small inspection cover near the clutch slave, so you do not need to take anything apart.
Jaap
Last Post by Ernie
12-17-2019, 11:34 PM
Last Post by Sculler
09-20-2016, 11:23 PM
Last Post by Bulti
08-30-2016, 01:12 AM
