Clutch Master Cylinder Torquing
Over the past year or so I have mentioned here that my '92 coupe has had clutch pedal issues, beginning with a slow pedal return. I did the braided hose fix and bleeding operation, along with trying the pedal adjustments. Today I recovered the car from Omega Motorsports in Jacksonville, where, among other things, I asked them to check the clutch adjustment. They re-bled the clutch and noticed the clutch pedal motion didn't feel correct. Investigating, they discovered that the clutch pedal master cylinder is torquing to one side when the clutch is operated--I watched as the pedal was depressed and saw the assembly move to one side. I'm grateful for this discovery, but Omega's man thinks I may need a good body man to weld up what he suspects is a flexing firewall and likely metal fatigue at the master cylinder mounting point. Tonight I will give the area a further investigation in the engine bay and clutch pedal mounting point inside. I'm wondering whether I might fit a steel reinforcing plate inside the firewall, or possibly mount a brace off the interior wheel well encircling and holding the assembly in place, or look for a competent soul to strip out the whole area and weld up whatever is flexing. Omega has never seen this condition before, and likely the same potential exists with the 944s. Anyone had the experience?
Ronald D. Keysor
I believe the experience, while not exactly common, has been known to happen. I would think it is more prevalent in areas along the coasts, with their salty air. It is why Flash created a reinforcing bracket, which is available through RS Barn, but unfortunately it is too late for you. Best of luck findng someone to fix it properly. Somebody who has had the experience should chime in soon with some good advice.
while the brace i did is designed as a preventative measure, i will have a version of the brace done in a couple of weeks, that should correct the failure - i already have the design, but have been buried with the supercharger project - i'll need to check it on a car with a cracked firewall to be sure, but i am pretty sure it will fix the problem - i'm not sure if i will do a batch or not though, as i have not yet spoken to pete about carrying them
Last Post by Ernie
12-17-2019, 11:34 PM
Last Post by Sculler
09-20-2016, 11:23 PM
Last Post by Bulti
08-30-2016, 01:12 AM
