06-06-2010, 04:12 PM
I was exiting the highway and was coming to a stop at an intersection. I pushed in the clutch pedal and it hit the floor and stays there. I knew something was up and was going to take it in to my mechanic. For the past few days I noticed the clutch was failing to disengage immediately taking what seemed like up to a second to come out of gear. Not sure if this is a typical symptom of a clutch about to die. It failed very quickly, probably 20 miles of driving from initial symptom to total fail.
I towed the car to my local shop hear in Vancouver and left it overnight for them to discover in the morning. Sure enough I need a new clutch. The clutch is original AFAIK, w/ 139,000 km (~86,000 miles).
They quoted two prices based on if the flywheel needed to be replaced. They indicated that they may be able to machine the flywheel and save me some $. Anyone done this? They figured 50% chance it was salvageable (they had not looked yet). These seemed a bit off to me as I figured if it is not to spec then replacement is they way to go. Either way they said it was a six hour job on a 968 (much more involved on a 944).
(This post was last modified: 06-06-2010, 04:13 PM by mrayner.)
