Threads: 11
Hi
I've checked this forum out and I can't find anything that is quite the same as what I'm experiencing. Since I'm not a great DIYer I'm ready to book time with my mechanic but would like to know what suggestions to make. Here's the problem. The clutch pedal goes to the floor and does not return. I can get it back up by putting my foot under the pedal and pulling it back into position. After doing this the clutch works just fine. It happened once last June, but gave no problem on a 4500 mile cross continent drive. It happened again a couple of weeks ago on an outing but just once. Two days ago, however, on a longer outing, it happened 4 times. I assume that this is a sign of worse things to come so I'd like to get it fixed while I can still drive it to the mechanic. Any suggestions as to what to give him a heads up about?
Steve
94 Coupe Black/Black, Option codes 288,331,398,425,454,490,650,
Threads: 224
http://www.968forums.com/index.php?showtopic=7517&hl=
It's happening to more and more of us. Can be tricky to find old post on these things though. Here is a post of a recent convo on a sticky clutch.
"Finally got my car up to the Barn and Pete broke it down for me. I'll try to repeat what I was told. It had to do with a pin that sits between a fork in the clutch mechanism. After sometime that pin gets corrosion/dirt build up and much like a door hinge, needs either cleaning or a bit of lube so as to function smoothly. He has seen this many times and that normally does the trick."
Try to copy and paste as I don't think I inserted the top link right.
Threads: 11
Hi
Many thanks for the information. This should give my mechanic a great head start at solving the problem.
Steve
Threads: 46
Very interesting. I have this problem now. A fellow from the forum came to test drive my blue 968. He ran the car rather aggresively on his test run. We turned around and the guy revved the motor to around 5500 and shifted into third - seemed like he stomped the clutch pretty hard and suddenly the clutch was on the floor.
We got the car home and looked under the hood. The upper clutch line is ballooning and the clutch will not return unless you pull it up with you foot or hand.
I'll go over the suggestions here and hopefully can fix this myself. Needless to say I am rather unhappy with the outcome of that test drive....as we were wailing down the road we passed my wife going the other way. She was FRICKING PISSED at the speed exhibited.
There will be rules for the next person driving my car on a test drive.
Benspeeder
BigSpeed Racing
1992 ITR Porsche 968
1998 Boxster
Threads: 48
<!--quoteo(post=73005:date=Jun 2 2009, 01:45 PM:name=benspeeder)-->QUOTE (benspeeder @ Jun 2 2009, 01:45 PM)
<{POST_SNAPBACK}><!--quotec-->Very interesting. I have this problem now. A fellow from the forum came to test drive my blue 968. He ran the car rather aggresively on his test run. We turned around and the guy revved the motor to around 5500 and shifted into third - seemed like he stomped the clutch pretty hard and suddenly the clutch was on the floor.
There will be rules for the next person driving my car on a test drive.<!--QuoteEnd--><!--QuoteEEnd-->
Not nice, but I guess the hose was on it's way out anyway. I am still dreading replacing my clutch hose with the braided version. For some reason I am really freaked out by bleeding the clutch.
I am following this trhead closely, hoping to glean some tips of it before I attempt this myself. Luckily my clutch overhaul is taking very long and I have time to mentally prepare myself for this step [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
Johann van Biljon
'60 Aetna Blue 356B T5 Coupe
'79 Silver 924 5 speed - Sold
Threads: 46
So I fixed my clutch problem with a little encouragement from Max at RS Barn. I replaced the bad clutch line and the pedal still didn't recover. I mentioned to Max that I was not putting the fluid in the Motul power bleeder and I had run the clutch dry the first time bleeding it - shame on me for a rookie mistake (wait, first time, I am a rookie!)
Filled the power bleeder with fluid, pumped it up to 20 psi and then pumped the clutch pedal about 20-30 times. Cracked the clutch bleeder which is located up above the starter motor and voila - a big air pocket bleeds out. Shut the bleeder. I pump the pedal a bunch of times. More air. Did this about 3-4 times and its fixed. There is more effort to bleeding the clutch than brakes.
Here's the mistake I made. Reading on the forum I got the advice to buy a Motul Power Bleeder - what a great tool for $60. One member said he was only using the air pressure and wasn't putting the brake fluid in the power bleeder. Sounded like a good idea to me since the instructions said to not store your brake fluid in it and I don't like messes.
That was the mistake because it allowed me to run the clutch dry and get MORE air in there. The beauty of the Power Bleeder is you fill her up, pump her up and then you don't have to worry about adding fluid as you bleed.
What a great sense of satisfaction as I hit some nice windy turns on my test drive - my blue barn find is now fully titled registered and insured, runs great and I still have a total investment of less than $3K into this car.
Next - timing belt - not letting that ruin my day - too many scary posts about that trouble.
Benspeeder
BigSpeed Racing
1998 Boxster
