08-06-2010, 11:25 PM
This is further to my post about my clutch master cylinder torquing to the side when the pedal is depressed. There is a fracture in the firewall (viewed facing toward the rear of the car) from just below the right hand bolt retaining the cylinder and continuing down, as far as I can see, to about 6 a.m. I found it impossible to reach the inner mounting surface behind the pedals, despite removing the driver's seat for easier access. The clutch cylinder is difficult to access under the hood because of the intervening AC line, hydraulic, and electrical wires. In the best of circumstances, I would think the best fix would be to remove all of those lines, dumping the newly refreshed R12 in this car, taking out the clutch cylinder, and somehow welding in a plate or whatever. Among the problems is the wiring bundle running through the firewall at about 5 oclock and very near the the fracture. That looks pretty scary if welding is involved. I have installed a clamping system bolted through the wheel well wall (along with a couple of other fixes) that have stopped the sideways movement of the cylinder and restored the clutch pedal feel. However, observing the clutch cylinder from above (the panel over it removed) while the clutch is operated shows a barely perceptible forward cylinder movement. I had put JB Weld on the crack to see if it reopened, and it has not, but the forward movement, though slight, seems ominous. I'm thinking after 150,000 miles that clutch pedal has done a lot of repetitions. Anyone dealt with this problem?
Ronald D. Keysor
