[quote name='MikeNH' date='Oct 14 2006, 06:48 PM']My inspection cap is missing. Seems thats pretty common. I have ordered a new but while I there what should I look on the clutch?
Is there something I should measure or otherwise check.
[right][post="26887"]<{POST_SNAPBACK}>[/post][/right][/quote]
Yes, you can measure from the end tip of the slave piston (back side of fork" to the far edge of inspection port, use a socket, this will give you the clutch plate wear. I don't remember the exact number but it should be greater (?) than 37 mm (?). I THINK that is the correct figure, anything less indicates a new clutch plate is needed.
Confirm those figures, I'm not sure about them.
