Threads: 24
My 968 has a nasty vibration at idle (clutch engaged and transmission in gear, or, clutch out and transmission in neutral) that persists across the power band, though it smooths out around 1200rpm and doesn't get really bad again until over 3000rpm. My initial guess was the engine mounts; Flash suggested it might be the balance belt. Well, apparently the mounts are fine and the balance belt intact; the mechanic thinks its the clutch; it's evidently quite worn. Mine's a '94 manufactured/sold in late '93, with a bit over 95,000 on the original clutch. Probably time to replace it anyway...
1) Does this sound like normal behavior for an old clutch?
2) What's the common gestalt take on replacement clutches? OEM? Better / cheaper aftermarket? I don't autocross or drive it competitively; best is maybe a spirited romp through the Santa Monica Mountains. I also clock very few miles on the car; it's logged about 3,000 since October of 2005.
3) How big a job is the clutch on a 968? My Jeep was a nightmare (and no, I'm not going to do the clutch on the Porsche myself, just want to steel myself for the mechanic's bill), but, it's 4WD with a transfer case in the way of the bellhousing and other fun stuff...
Thanks!
Bone-stock '94 968 Cabriolet, '95 Wrangler SE 4.0L, '06 Ducati Multistrada 620 Dark
Practicing law and hacking code in Los Angeles, California (southbay, Miracle Mile, westside...)
Threads: 6
a worn friction disc shouldn't cause bad vibrations like you speak of.
unless it's to the point of pieces flying off, but i'd think you'd feel that in the pedal.
but it could be a possible sign of a failing dual mass flywheel?
i think the oem clutch is just fine.
they also make a sport version.
the 968 clutch is quite easy to replace compared to most other cars.
no tranny removal required.
just remove the cat back exhaust and there is a access panel on engine bellhousing to access the clutch and flywheel.
i just did the clutch on my nissan 4x4 so i know how that goes.
the 968 is much easier.
[color="#3333FF"]Todd Jacobs [/color]
[color="#339999"]Iowa, USA[/color]
[color="#FF6600"]1993 968 coupe 6spd[/color]
[color="#000099"]Cobalt Blue [/color] with [color="#000099"]cobalt [/color] and [color="#CCCCCC"]light grey [/color] interior.
[color="#FF6666"]17" 996 wheels, Koni's, LSD.[/color]
Threads: 167
It's entirely possible that the DMF has failed. Ths will usually cause a VERY noticeable vibration through the shifter. If you are going to replace the DMF you should look into RS barns (See Banner to the Right>>>) new Lightweitgh flywheel...better performance, similar $$$.
Regards,
Jat
Threads: 35
Or...AllGermanParts will sell you a nice new old stock LuK Dual Mass Flywheel for less than $700.00 ($635.00 a few months ago)...
Either way, it's a good deal! But... I believe the RS Barn unit will still have some vibes at around 2,200 rpms... And reve faster too!
You pays your money and takes your chances!
Threads: 31
If it is not the flywheel then it could be the balance shaft is 180 degrees out of wack. They are keyed on both sides for some reason. When mine was out of whack by 180 the vibration was so bad starting about 3-3500 rpm the heat shields were banging around under the hood from it.
