OK, here's what was going on with my 951 cab.
A few months ago, the car began behaving erratically due to what I thought (rightfully) was an electrical issue. After replacing the TPS, ISV, etc., the car still ran badly and we went through endless trials and tribulations until replacing the DME control unit itself, which solved the problem.
Along the way, the car spent some time in a shop that tested lots of stuff and probably pulled some relays in the fuse box.
On the 944 cabrio, there's a turquoise blue relay in the G21 position that has a 941 reference and is specifically for the electric top mechanism. Two positions in front of that relay (position G19, I think), there's another relay (also turquoise blue) with a 928 reference that's for the central locking and alarm systems.
Since I have two cabs, I started substituting these relays from the S2 to the Turbo and noticed they were reversed! The shop had probably confused them, since they're both identical except for the reference numbers.
Switched the positions, putting the 928 relay in the G19 position and the 941 relay in the G21 position, and both the central locking and electric top mechanisms became fully operative again.
Now while you may not have switched relays, you may want to check the relay in position G19 and see if it's in working condition before checking the central locking control unit itself.
If you have a cabrio and the electric top mechanism is inoperative, you may want to check the 941 relay in position G21.
Thanks for the responses!
