Auto Locking and Alarm
Hi, my 968 Cab seems to be haunted.  Since I had it, it will randomly lock the doors, sometimes with the key in the car.  I've been carrying around the spare as well.
In some cases, I will lock the door and it will immediately lock itself again after I take the key out.  Sometime the alarm comes on when I open the door.
Is there any way to disable this system, or just disable the autolock (fuse?).  It's a cab and I'll never lock it.
Start by getting some lube in the lock solenoids. If they don't lock all the way, the computer tries to cycle the locks again. Once they are lubed and they work more smoothly they will be less likely to misfire and try to lock you out.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Ok, good idea.  Do I need to take the door card off to do that?
Last Post by Westy
05-04-2021, 11:46 PM
