01-21-2014, 03:28 AM
I've got a new Head unit in and the sound is much improved. I really like the HD radio (Alpine BT149).
I want to install new speakers in my Coupe.
Here's the question. I bought a JL audio 5.25 inch speakers (VRs) with integrated tweeters to replace the door panels. They are 4 ohm speakers. Unfortunately, these are low in the door. I'd like to use the additional tweeter up higher to get a little added "brightness".
How best to do this? Should I just forget it?
Should I wire in the JL audio's, then split the signal to the existing crossover (parallel) to the tweeter. (Input to 5.25 speaker, parallel to crossover with the signal still attached to the tweeter).
With these JL Audio's, do I need a base blocker?
Do I need to replace the existing tweeters? They don't seem to be blown.
I've got a set of 6.5 inch JL Audio VR's for the back (will try Flash's speaker box mod). These have a remote tweeter that I'll put in the back next to the woofer.
Sort of related, I read an article on sound deadening. They recommended using the stick-on sound deadening material, like dynamat extreme with something like 25% coverage. The idea is like putting your finger on a surface of a drum. He adds that you then use a less expensive and thicker material to adsorb the sound. He recommended using Velcro to attach this. Any opinions on this? I've seen plenty of articles where the entire car becomes covered in Dynamat extreme.
Seems to me, that on a coupe, the back wheel wells and hatch generate the most noise. I'm thinking of using this 25% coverage rule and a thicker and less expensive material back there.
Thanks for advice.
Thanks for advice.
