reverse light and rear window heater/demister problem
Hi Guys
I'm back for yet more help.... sorry!!
As title says both reverse lights and rear window demister are not working a quick look at the fuse box showed that they both run of the same fuse a 30amp. I thought great must just be a fuse so i replaced it and it blew its self immediately.I tried this 2 mopre times with the same results.
Any ideas? all other fuses are ok and they both have worked in the past a little confused by this.
Thanks in advance for any help.
regards
there is a wire located at the hatch shock that is known to break
Hi flash when you say its known to crack there are two points where that wire connects. where does it usually break??
i will have a look in a little wire although i did look at both the onnections on the boot lid shock all seemed ok but knowing me i probably missed something.
thanks pal
not sure if it's power or ground, but it's for the demister/defogger thingy. no idea if there is a common point with the reverse lights. i haven't looked at the diagram.
thanks bud
Could be the hatch wire mentioned by Flash. Mine was broken and demister didn't work. Fixed it and voila! demister works again. It is located on a left side of the hatch (driver's) next to the shock which helps to raise the hatch.
Quick update i found the wire it was broken on the offside of the car connected to the strut. i reconnected it but the fuse blew immediately. I then disconnected the one on the strut and put a new fuse in still it blew again. As i disconnected it i assume the problem is something to do with the reverse light side as the fuse still blew.
Any help would be great.
well, now you get the distinct pleasure of tracing the power wires to the short.
i would start by removing the bulbs from the reverse lights and seeing if the short is there.
listen to Bob, he's worked on more British cars than just about anybody so if there is a problem with electronics, chances are he's seen it.. one of those " been there, done that " scenario ..
Btw, talking about rear window heaters : you do know why British cars have rear window heaters, right ? It's so your hands don't freeze when you push the car home in cold weather ..
  • Lucas - The Prince of Darkness
  • The Lucas motto: "Get home before dark."
  • Lucas is the patent holder for the short circuit.
  • Lucas - Inventor of the first intermittent wiper.
  • Lucas - Inventor of the self-dimming headlamp.
  • The three position Lucas switch - Dim, Flicker and Off.
  • The Original Anti-Theft Device - Lucas Electrics.
  • >Lucas is an acronym for Loose Unsoldered Connections and Splices
  • Lucas systems actually uses AC current; it just has a random frequency.
  • "I have had a Lucas pacemaker for years and have never had any trou..."
  • If Lucas made guns, wars would not start.
Chris Vais
2008 Audi A5 Brilliant Black
You guys are funny.................very good but don't go into stand up comedy!!!
will try what you said flash
will report back tomorrow
thanks again chaps
Ok so here is how big an idiot i am. Finally found the problem.
When i fitted the rear wiper delete bung i disconnected the rear wiper plug, which i know is fine but listen to what i did next, in my infinate wisdom i decided to cut the plug off and tape the wires together, which kept shorting the fuse. <img src="/forum/images/smilies/968/ninja.gif" class="smilie" alt="" />
We only realised this when the wires that were taped together decided to smoke and almost catch fire......
Now i have another problem which is the i need to disconnect the wires from the fuse box for the wiper as the wires somewhere within the car are shorting as the fuse keeps blowing.Probably as over the last month they have been getting hot!!
Please can you advise me on which relay is responsible for powering the wiper.
You are all more than welcome to call me a fool
thanks in advance for any help
"The only foolish question is the one that doesn't get asked"
Sorry I can't suppy you with the answer, but someone here will...
You will also have to find the Porsche part number for the smoke you let out. It has to be replaced or the car won't fail properly. I believe it's kept in the ECU at about .3 bar. <img src="/forum/images/smilies/968/tongue.png" class="smilie" alt="" />
Last Post by lbpesq
04-16-2025, 12:42 PM
Last Post by pte
06-14-2023, 06:33 PM
Last Post by Westy
05-04-2021, 11:46 PM
