05-05-2008, 07:06 AM
Well, I pulled my brake pads this weekend for the first time ever on a 968, and found it both good and ugly. There were two things that hampered the pull. The wear sensors and the anti squeal hats.
I had a devil of a time pulling the wear sensors. I managed to break both sensors on one of the rear brakes, afterwhich I stopped and had a beer, because I must be doing something wrong. Still haven't figured out how to do it on the other wheels......need some help. I really don't need the sensors but wnated to keep the car stock. Is there a way to replace the ones that I broke?
Then on to the pads. This is my first experience with Brembos, and the use of the single spring to hold the pads in is ingenius. Then I went to pull the pads and they would not come out. Guess I should have read the manual first, right? Not knowing how hard it would be to follow the manual and use a "spatula" to seperate the the anti squeal from the pads. Finally just pulled the caliper and then pushed the pads to the center and pulled them out. Is there a simpler way to prevent squeal? Or do I need to resue the hats. If I do, what is the best way to install them with some sort of glue?
Thanks.
Ernie
Thanks.
Ernie
