Brake Reservoir during overhaul
So there I was, side of the road, clutch pedal to the floor, waiting for the AAA flatbed to arrive (thanks for that tip Flash, already paid for itself).....
High pressure hose is split vertically at the metal/rubber junction, not really surprised after researching here.  I'm going to replace the two cylinders as well.
Further down my list of ToDos was front wheel bearings and a full on brake job.... rotors/pads, caliper inspection/rebuild (maybe some paint), SS lines, fluid change.
Is it acceptable to vacate most of the fluid out/have the entire system drained and start fresh once everything is re assembled?
Any problems if it takes a couple weeks with the hoses and lines empty? What about while filling it all back up...can I bleed the lines with my Motive from dry state by just pushing the air out with the new fluid (using proper sequence, of course)?
Or do I need to do this in stages, keeping the system filled?
Ever feel like you're buying a new 968 in $300 project increments?   LOL
$300? I thought a PMU was $1000.
And yes, I think of that all the time, then I think of a car payment, and that "cool Camry" has been said by no one ever, and I fix it and drive it some more.
See if Flash (Design1Racing) has any SS Clutch lines...worth their weigh in Brake Fluid...
i stopped making those.  i had to make too many in order to get a decent price, and the fittings i had to use were SAE.  a couple of guys just couldn't get their head around not being metric, so rather than have any complaints, i just killed the product.
so........
completely drain the system, then?
^_^
not only would i drain the system, i would flush out the brakes when you fill it back up, as they share the reservoir with the clutch, and any contamination in one system is most certainly in the other.
Thanks Flash.
Last Post by IndischRot968
07-21-2025, 11:46 AM
