brake disks for M030
Hi guys,
I have an M030 968CS.
I have the stock cross-drilled disks on it and run Hawk HP Plus pads (I think). It's time to change the disks. The car is used to do autocrossing and on-road rallies.
The stock front disk part numbers are 965-351-041-01 (L) & 965-351-042-01 ®
Rear disks are 951-352-041-91 .
Anyhow, who makes the OEM units and are aftermarket disks such as Zimmerman better than OEM (does Brembo make aftermarket disks) ? What dealers would stock these (I'm in L.A.) ?
Many thanks,
Steve
the OE rotors are expensive, but they are the best by far. the holes are cast not drilled. i have had bad luck with zimmermans, out of parallel & cracking. they also do not have a coating so they rust.
steve - you have a PM
Last Post by IndischRot968
07-21-2025, 11:46 AM
