Hi, I'm up to my shoulders in the oil-pan-gasket repair - suspension removed, PS rack disconnected at the pump, engine supported from above (harbor freight support is much sturdier than the one my PM uses), crossmember bolts removed.
The only things holding the crossmember on now seem to be the steering input spline (bolt has been loosened) and the engine mount top bolts (bottoms have been removed).
Those top bolts for the mounts are a challenge for access, plus they're fastened really tight. Ive soaked all these with PBB last nite and will try again this morning, but does anyone have additional tips? Maybe there are other ways to try, like unbolting the upper mounts from the block (not crazy about that idea though)?
I'm replacing mounts with OEM, and will also do Koni front strut conversion and replace bushings with OEM while-I'm-in-there
--Michael
