a little help for a rookie, please.
i've got a small leak from some kind of sensor in the oil sump. not enough to worry, but enough to leave a drop or two over night. not sure what it is. also not sure if i should order a new one or try and remove, clean, and re-seal it up.
also, it looks to me like there's a drain plug on each side of the oil sump. does anyone know what that's about? is one plug and the other something else?
this sensor that's leaking is located directly above one of the drain plugs. i think on the passenger side, but i'm not sure.
i looked it up on pet, but the diagram of the oil sump only shows it from one side.
thanks for any help.
