06-12-2006, 05:47 PM
After replacing the clutch I found my clutch master cylinder was leaking so I ordered the master cyl and the pressure line, the supply hose had been replaced by PO earlier.
After installing the parts I tried to bled the system, it took me many tries to get it right, here's what I learned.
First let me say when I've used the Motive bleeder in the past I did NOT put fluid into the Motive tank, I just made sure not to run the brake reservoir empty when bleeding brakes. This has always worked fine for me in the past even when bleeding a clutch system that only needed flushing. I don't like fluid in the tank since it will absorb water and can get contaminated in the tank easier than in the brake fluid can.
Unfortunately I learned the clutch portion of the reservoir inside the brake reservoir is very small, when using a pressure bleeding system (Motive) it is very easy to empty the clutch portion and get air right back into the clutch lines. Unfortunately, leaving the bleed screw open long enough to get air out the bottom the clutch portion of the reservoir winds up draining the clutch area and sucks more air in from the top! I'm embarrased to think how many times I did this.
So, I used some fresh clean fluid, rinsed out the Motive and put about 1/2 qt. in the Motive tank. Proceeded to pressurize the system, 8 lbs will NOT work, it won't get the air bubbles small enough to flow through the entire system, I wound up going to 18 - 20 lbs. After bleeding with a steady supply of fluid on the reservoir end and using a sufficient pressure from the Motive the system bled very quickly, I still had a good bit of fluid from my 1/2 qt in the Motive.
The pedal did feel a little strange but after driving it a few days it's feeling much better, as others have suggested I'll give it a few more days and bleed it again.
Bill W.
'93 968 6 spd. coupe; '97 993 Cab
'91 BMW R100GS/PD
