big reds
hi there guys, can anyone tell me what are the best rotor hats for mounting 993 tt discs on to my mo3o hubs on my 968 clubsport, kokeln have some wicked stuff, but dont list any for 968s. <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" />
The M030 hub would be the same as the 89 944 Turbo (S). I'm sure Kokeln could set you up with the correct set if you contact them.
You could also use the one piece 965 rotors and skip the hats.
Eric
Lindsey Racing in OKC is where I got mine. I was not able to find any source for Kokeln hats; they seem to have quit offering them, at least through retail channels.
Oh and the folks at Lindsey are very knowledgeable and helpful, you'll like doing business with them.
Any weight savings here? The Brembo ads seem to imply that there is significant weight savings just by using their new rotors with stock calipers. Good luck, Bob Blackwell.
I have 993RS one piece rotors. If i remember rightly you have to use the 965 rotors with 030 spindles (i assume you are using big reds). The 993RS discs have a shallower top hat (5mm), i use adaptors with standard 968 spindles.
JP
The brake rotor disc from the 965 with the 3,6 l engine are the right one if you use the 993 turbo (red) ord the 968 GTS (balck) brake caliper.
The number are:
965 351 045 00 brake rotor disc 964 turbo left
965 351 046 00 brake rotor disc 964 turbo right
Last Post by savvas968
01-15-2011, 07:49 AM
