Another brake question...
When I was removing my front calipers last night, by removing the large, 19 mm head bolts that hold the calipers to the hubs, I found that on the passenger side only, there is a spacer on each bolt that sits between the caliper and the hub. It looks just like a washer, but it's a little thickner than a normal washer.
The strange thing is that these spacers are only on the passenger side - the drivers side doesn't have them. My brakes were upgraded by the PO to "Big Red" calipers, though I'm not sure of the actual brand, with Zimmerman cross-drilled rotors. I called my local Porsche dealer, who told me the spacers show up as belonging on the M030 cars, but not on the standard model. My car was not an M030 car. I know for a fact that thicker versions of the same spacers are on my back calipers, on both sides. Any idea what may be going on here? I would assume I should have them on both sides, right? They're dirt cheap, at 54 cents apiece (the rears are over $5 each!), so I went ahead and ordered a pair. Thoughts?
As far as im aware.
These "washers" should sit between the bolt head + the calliper, NOT the calliper + hub.
It might be the PO did this to space the calipers off the hub centrally because the adapters wernt the correct thickness...
Im presuming you have adapter plates fitted .?? As you say you dont have the M030 pack, ie different spindles....
Sorry, what's an adapter plate? The brakes and suspension on my car (see my signature) were all done by the previous owner, so I'm afraid I don't know, or at least don't remember, many of the details of what he did. It is weird that these spacers are on one side and not the other. And the diagram at the dealer does show them, at least on the M030, along with a part number, and they're definitely present on both of my rear calipers.
To fit Big Reds or M030 calipers to our standard cars, you need a adapter block. BUT if you have the M030 spindles then you dont need these blocks.
It might be the PO fitted the full M030 pack...You lucky person...I see in your sig, it has had some different parts fitted along the way....
OK, I thnk I know what you mean. I do have a rectangular block, which is between the caliper and the hub. It has two bolts with 19 mm hex heads running through it that attach the block to the hub, and two large allen-head bolts (9 mm, I think) that hold the caliper to the block. On the passenger side, there are spacers that fit around the hex-head bolts, between the adapter block and the hub. These spacers don't exist on the drivers' side.
Any pictures?
[quote name='Cloud9...68' post='65535' date='Jan 13 2009, 02:55 PM']OK, I thnk I know what you mean. I do have a rectangular block, which is between the caliper and the hub. It has two bolts with 19 mm hex heads running through it that attach the block to the hub, and two large allen-head bolts (9 mm, I think) that hold the caliper to the block. On the passenger side, there are spacers that fit around the hex-head bolts, between the adapter block and the hub. These spacers don't exist on the drivers' side.[/quote]
Thats them....
These adapters a sometimes "universal". In the respect that they can fit the M030 calipers +/or the Big Reds, to the standard hubs.
If you look at the pic ive attatched youl see on the right hand bracket the holes are offset. These are there to centralize the calliper on the disc...
All you do is turn the adpter plate round.
The M030 calipers + Big Reds have a slightly different "offset" .
What might have happened is the PO fitted them "slightly" incorrectly + thought he needed to space them out accordingly.
I bet if you take off the block + turn it round [ youl just have to do a few trial fits], youl get it to fit without the spacers...
Last Post by IndischRot968
07-21-2025, 11:46 AM
