A funny thing happened when I changed my oil...
#41
Part of the Mobil 1 issue is the definition of synthetic. Castrol paved the way for using highly refined mineral base stocks and calling them 'synthetic' oils, won a court case, and once the cheaper base stock could legally be used with Synthetic on the label other companies using PAO base stock could not compete price-wise.
The highly refined Group III base stocks are great but slightly less great than 'real' synthetic IMO. I call them 'sorta-syn.' I use a ton of these type of oil, mostly Shell Rotella T Synthetic 5w-40, and I have not had any significant problems. If I had a modded turbo car (more modded than my slightly boosted Saab 9000) I'd probably run something more exotic in that so I felt better about the heat.
I do have a jug or two of M1 15w-50 left over from my old 944 Turbo supplies, I might try it in the 968 one day just to see how it goes. It was a good oil for me when I used it regularly. I have been using the Rotella T in my motorcycle, Audi A8 and 928S4. The price is good and both of the V8s take a lot of oil for a complete change. I just changed the 968 over to it from whatever the PO put in it as well.
Oh, my motorcycle has a dry clutch but with a wet clutch I'd be worried about some of the friction modifiers in some of the newer oils... Rotella I think is not one of those oils but check first and consider using a motorcycle specific formulation if you have a wet clutch. I ran my CBR1000 on Rotella T for a year or so before I sold it, clutch worked fine, but I would hesitate to use a regular car formulation and would double-check Rotella's specs before I pour it into a wet clutch bike.
One thing I like about the Rotella is that it still has a decent amount of ZDP in it. I'm not sure about the cam failures and ZDP problems but since I have used oils with ZDP in them for years and years of enthusiastic driving and riding without oil related problems I'll be one of the last people to abandon it.
-Joel.
Joel Frahm
1987 928S4 Diamondblau/Blue
[quote name='flash' post='39337' date='Aug 2 2007, 08:38 PM']i found a noticeable change when i went from mobil 1 15/50 to redline 10/40
1 - my wallet was lighter
2 - i have to drive 15 miles to find it
3 - i have to stock more of it because of number 2
4 - number 1 is exacerbated by number 3
seriously though, my engine does run a bit cooler on the oil temp, and it does seem to spin a bit easier[/quote]
Flash,
I know it's been awhile, but do you remember approximately how many degrees cooler your oil temp became when you switched to Redline 10W40? I'm about to put the same stuff in mine, so I'm anxious to see if it has any impact on my water temp (not expecting a big change or anything, but every little bit helps...). Thanks.
about 5 degrees at the track - that's a LOT - remember, this is oil temp, not water temp as would be shown on your dash guage
Last Post by unknown4u
12-17-2023, 08:16 AM
Last Post by J.Elenbaas
06-13-2020, 05:17 PM
02-20-2020, 08:48 AM
Last Post by MCL968
02-18-2020, 02:45 AM
07-29-2019, 02:08 PM
03-20-2015, 07:14 PM
03-07-2015, 06:45 PM
