Threads: 137
I think that a big problem for us Porsche owners is transferring the knowledge that is out there for the general car population over to our cars. Porsche engines are not made the same - harder materials, different clearances, etc...
So this translates to the many discussions floating around. Over on the bobistheoilguy site, it's even nuttier because they're all talking about almost every car on the market!
Here's my summary of thoughts - as an engine gets older and the wear makes the clearances greater, a higher weight oil will help it run more efficiently. But with our engines, where's the wear? If you're just driving our cars on the street with an occasional DE, 250,000 miles on our engines is nothing. The word floating around the Porsche mechanics I've talked to is that our engines basically don't hardly wear at all.
So then what do we do? I think that that the 5w-40 or 10w-40 oil is THE way to go for our engines. Amsoil's Euro blend, which is Porsche approved, comes only in 5w-40, so that's why I'm using it. If they had a choice to 10w-40, I would have picked that because of the high heat down here.
Bottom line is that with all these theories we all have - it's hard to quantify who's is right/wrong because of the relatively small number of 968's. For my thinking, I'm including the 87 and up 944 2.5 liter engines because except for the oil squirters, they're basically the same engines we have. So I think that's where we can get some comparisons from.
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 137
blending of oils is a hot topic over on the bobistheoilguy forum - summary - it's best left to a oil engineer and even they argue about it! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
The recommendation over there is to NOT run ANY blends of anything - we don't have the expertise to know if one small ingredient in one oil will affect the other brand.
suggestion - Why don't you'all wait for my "End of August Report" before making any decisions? I just changed from almost 5 years of running Mobil 1 15w-50 to Amsoil 5w-40 about two weeks ago, I also had no leaks. One month isn't going to change things greatly. Besides driving over 90 miles a day back and forth to work - I'll be doing an all day hard run out in the hill country on Aug 12th.
Sound good? <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Many happy smiles...
Michael Sorbera
2002 VW Beetle TDI
Threads: 137
flash - i was wondering about that - does a thicker viscosity fluid wick away the heat better?
Michael Sorbera
2002 VW Beetle TDI
Threads: 24
Hi,
Just to let you know what kind of oil I am using, at the moment it is a fully synthetic 5W40 made by Duckhams...no leaks & problems. But then again I am living in The Netherlands and the temps. are not that high as in some parts of the USA....
1992 Amazon green convertible. Cargraphic cat. back exhaust, RS Barn/ Design 1 Racing lower & upper strut brace, RS Barn stage 1 Chip, Airbox modification, M030 Swaybars.
Threads: 137
Michael Sorbera
2002 VW Beetle TDI
Threads: 137
If I remember correctly, one of the bizillion posts I read was from a guy that said he actually tested brand new bottles of Mobil 1 and said that chemically, they were not pure synthetic any more, but a blend of dino oil synthetic.
The email from Mobil 1 claiming they are still 100% synthetic is interesting - "All Mobil1 motor oils are still 100% and fully synthetic motor oil formulations." 100% what? "fully snythetic motor oil 'formulations', so what does 'formulations' mean? According to what I read it's like 'natural flavorings' in foods - you can put just about anything in and call it a 'natural flavoring'. So a 'formulation' is just that, a blend of stuff, and as long as it's a small percentage, that small percentage can be dino oils.
Hope that makes things as clear as mud! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Michael Sorbera
2002 VW Beetle TDI
Threads: 26
To answer the question earlier about if anyone has changed from a heavier grade oil to a synthetic lighter oil. I have some experience. When I bought the car, the previous owner had been using Castrol GTX dino oil 10w-30 I think. Dino oil in general tends to be a little heavier than its synthetic counterpart. I switched to Lubro Moly Voll-Synthese which is a 5w-40 full synthetic. Instantly the oil leaks that I had became more pronounced. Since then I have had all of my leaks fixed and everything is happy. It may be a cause for concern but I see the good in it. It tells me that the synthetic oil is able to penetrate better. So despite the problems it caused in the beginning, I have a better peace of mind that my engine is being well lubricated. Also I have been using this oil in all of my cars and have been very happy with its durability. 136K on the clock.
[color="#0000FF"]Brian[/color]
[color="#4169E1"]My Collection:
94 968 Midnight Blue
95 Audi S6 Avant (Seattle)
93 VW Corrado SLC
91 Audi 200 TQ Avant[/color]
(This post was last modified: 09-20-2007, 02:51 AM by
kodomokid.)
