10-18-2014, 04:10 PM
To get to this seal the intake manifold must be moved out of the way. I disconnected little bits at a time and was able to invert it, along with throttle body, upside down over the top of the engine (the cam cover had also been removed for other repairs, and I needed that clearance too). I didn't have to completely disconnect all this from every vacuum line, and I didn't disconnect coolant hoses from the throttle body.
So inspection of the rear seal of the upper balance shaft revealed a rattle-y loose seal (that would be a bad thing, right?), and a puddle of oil below it. Hmm, I think that just maybe oil has been leaking here recently...
So, I think I read that the entire cover for the balance shaft must be removed (maybe even the BS itself?) in order to replace this seal?
I am considering following the suggestion of MBardeen, who sealed the one on his car with some of the RTV730, which I already have a tube of (its horrendously expensive, but good stuff). Gotta clean everything scrupulously first though.
So whaddaya think? I've got access to the upper BS housing? Go all the way, or try the RTV first?
