Threads: 177
I need to remove the rear wing as it is ready to fall off. I am hoping that I can find out why it is loose and make some new re-attachment points as needed. It rattles so much that it is very annoying. Has anyone ever done this and then been able to make it tight again? It seems as though some "bolts/screws/fasteners" are missing, others are loose and some just don't seem to me to be able to be tightened.
Kim Strong, Nova Scotia
2022 Mustang Mach-E
Threads: 177
Thanks. That seems a rather good description. I will try this on the weekend.
2022 Mustang Mach-E
Threads: 177
So the wing is off and the fibreglass was actually broken away (before I owned the car) in one area. See pic.
The PO then drove a screw into an area beside it to hold it. Anyway, The wing is off and I am going to have the damage repaired. I am also going to try to find some thin foam to cover the attachment area on both sides to keep the rattling down a bit.
Lesson - don't use the wing to close the hatch.
I also noticed that as Dave and Xrad said two of the screws holding the side trim panel have pulled loose. Can't post a pic because this one used up almost all the space but will post a second one below. I may just try to buy the piece new if it is available and not too pricey and replace it. I also will likely buy all new fasteners all the way around to deal with rust.
2022 Mustang Mach-E
(This post was last modified: 06-06-2009, 12:44 PM by
Kim.)
Threads: 177
This is the good side
This is the side piece -
I had to fool with the image a bit to get it below 500 kB
2022 Mustang Mach-E
Threads: 177
I also noticed that the hatch wouldn't open and I had to climb in the back to pull on the manual wire. the part that attached to the shaft of the motor had broken. Anyone ever had to replace this?
2022 Mustang Mach-E
Threads: 20
One thing I learned from Porsche on this forum is to close the hatch by pressing on the frame of the window right above the two lock mechanisms. Good luck with the fix!
Threads: 177
repaired with new fibreglass
then covered in black cloth (ie hockey) tape to hopefully cut down on the squeaks when it is installed.
2022 Mustang Mach-E
Threads: 177
Wing is done. Held on now with four bolts instead of two. No rattles, wiggles, or anything. First Saturday I have taken off from work in about 8 months and it was worth it.
2022 Mustang Mach-E
(This post was last modified: 06-06-2009, 08:37 PM by
Kim.)
Threads: 224
Are these the right screws to remove? (the 2 phillips to the left of the wiper motor) When I try to back them out the screws they just spin in place as if they have no threads.
Looks like I'm going to have to remove the hatch window trim to access the bolts described above. Man am I glad this thread was here. Here I thought Id have this off and the new wing on in 20 minutes. [img]style_emoticons/<#EMO_DIR#>/mad.gif[/img]
Any other tips are welcome.
http://img706.imageshack.us/i/p10301710285683.jpg/
http://img52.imageshack.us/i/p10301690278511.jpg/
(This post was last modified: 03-18-2010, 07:21 PM by
rhudeboye.)
Threads: 177
Those screws cover the side parts of the wing that cover the glass attachment. I had to take them out at the bottom because the smaller "wing" that you push on to the close the trunk needs to come off to get the main wing off, and it slides under those side wings. The side wings are held on with a funny circular sort of slotted nut and you only need to take the ones off near the bottom. The main wing nuts (ha ha!) are four larger ones that clearly go through to the wing itself. Take them off and the wing comes right off. It is awkward and a bit heavier than you might think and will tilt if you don't hold it firmly. I would hate to see a pic of it through your back glass.
There are four parts - the main wing held on with four (or perhaps fewer) bolts, the centre smaller metal wing (there is a bit of wiring under there for the wiper motor) and the two side wings. They all come off very easily but the side wings only need to come off at the bottom if all you want to do is remove the main wing. If you want to remove the glass all parts need to be off.
If those screws are spinning it is because the threads on the female end have stripped or the nut has fallen off (can't remember which). I simply replaced them with a small bolt and nut with a washer.
2022 Mustang Mach-E
(This post was last modified: 03-18-2010, 08:56 PM by
Kim.)
Threads: 224
Thanks guys. This really helps. Its dark out but I gotta get this thing off as I have prematurely listed the wing on ebay. Guess Ill go at it now. 9:00PM
Step one- remove lower wing to reveal screws. (Use a make shift tool as I dont have a fork shaped screw driver).
2. Back out screws to upper wing while holding the nut at the top.
3. undo the bottom half of the left and right window trim to reveal the front screws holding the wing (one screw per side).
Does that sound right?
Threads: 224
Big Thanks Dave and Kim. I got it. I took a bunch of pics and Ill try my hand at a DIY when I get some free time.
Threads: 224
Needle nose Vice grips work well also and will prevent loss of the item when it spins loose.
Threads: 42
Had my car over at provost and they fixed my wing. It was pretty loose. Max did a phenomenal job, the thing is on really tight now, like the day it rolled off the factory floor (probably better). Highly recommend these guys if you need your 968 fixed, they know everything about these. Also had my starter replaced as well.
2005 Acura RL
2004 Toyota Sequoia
