05-12-2015, 04:53 PM
Well this weekend I'm upgrading to Robby/IceShark cables and a new alternator. Last weekend was a sunroof fix (more on that below). That means to get to Maintenance Backlog Zero all that's left is
If you're familiar with the geometry of the sunroof struts, you know that the struts engage the sunroof through a slotted fitting such that if the strut is withdrawn all the way you can take the sunroof out, if engaged just an inch or so, the sunroof is locked down, and if engaged more than that first inch, they start to push the sunroof up.
And the google tells us that mysterious failures of this mechanism remain even when folks have otherwise adjusted everything to spec.
The driving mechanism uses slotted holes to bolt it to to the roof, allowing for adjustment by sliding the entire gearbox forward or back. The failure mode I discovered is, in my early '92 car, the gearbox could not be slid back far enough to allow the strut to easily slide into the sunroof slot - the strut ends up being too low relative to an ideal path of travel. So every time the sunroof is closed, the tab needed to FORCE its way into the too-high slot through to the "lock" position which really clamped down the sunroof as it attempted to get in there.
So... lots of stress on the gear - eventually it gave up the ghost.
The remedy is to remove the plastic gear mechanism from the car - four bolts - and extend the slotted holes in the right direction to allow the gearbox to slide back the additional 3/8" inch or so. I used a drill bit that matched the ID of the hole and just let it chew back into the plastic a bit.
Once this was done it was very easy to adjust gears and struts, check alignment, and bolt it back up. The struts now slide into the sunroof slots with hardly any resistance at all... just enough to keep the sunroof tight at speed.
And yes, my sunroof was adjusted all the way down already (the plastic adjusting screws in the sunroof gutter). Seems like a case of slightly-wrong build dimensions out of the factory.
Cheers.
- hatch glass
- paint repairs (don't ask!)
- rocker panel rubber
- passenger door latch
- motor mounts
- oil change
- coolant slow leak
- etc and so forth and so on
Cheers.
