Threads: 63
Bracer,
Sorry about your sunroof issue. I wish someone would come up with a manually operated lever from the inside
to get rid of the entire quirky mechanism. It's a real PITA. <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" />
I've been through numerous plastic gears, but it seems like that's not your problem. Have you checked
underneath the carpet near and above the driver side rear tire? The motor and micro-switches are located there and
you might check to see that none of those tiny screws that hold things together back there have come loose
of off entirely. I'm no expert, but it's worth a look I think and it's easy to check. Best of luck.
Cheers!
SOLD! 1992 - 968
Threads: 51
Just like Porsche to over engineer a simple device into a nightmare. There are so many micro switches and crap that can be out of wack that only a pro can set it all correct again. "lets add some more weight and complexity" Sorry for the rant! I have done the gears on my 944.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 24
Clarks's Garage has a pretty good write up on the entire sunroof mechanism. (
www.clarks-garage.com/). On the left click on the Garage Shop Manual link and the go down to the "S" section for sunroof. Three good articles.
'93 968 coupe Black/Grey, 6 speed, 17" Factory C2 Turbo Wheels, Griemann Grills, and more once funds allow.
Threads: 63
I used to own a 924 and do miss the simplicity of the roof panel. It just had 2 latches that were also used to prop the panel open. There were no gears or m/switches to mess with.
I wonder if those 924 latches could be used in our 968's?
SOLD! 1992 - 968
