Threads: 224
Not a cab but this seems to be the best spot for my question.
I'm finally getting around to my sun roof repair. Are
these
gears just as good as any? Is this all thats needed when your roof doesnt fully lift up? If the ebay gears are garbage would someone who successfull changed out theres please provide a source.
Thanx guys
Threads: 59
I've gone through this drill twice now. Both times I used Porsche factory replacement gears. I believe that successful and long lasting repair has less to do with the source of the gears and much more to do with the proper adjustment of the rest of the system as described in DIY section. The electrical relays must be propery adjusted. If they are not the gears will be stripped.
One other suggestion, if you occasionally remove the sunroof. When you are retracting the rear sunroof arms in preparation for removing the sunroof, stop the retraction process just as the arms clear the slots in the roof, do not retract them all the way. If you let them retract all the way, you may end up with stripped gears.
Chris Vais
2008 Audi A5 Brilliant Black
