weight will be an issue - so could be alignment and/or tires
when you go that wide on the street, you can pick up tramlining and wandering - the alignment becomes more critical - i don't know if 9s can be run up front on rubber bushings - they may flex too much to allow a stable set - you may have to change to spherical bearings, which means more cost
i'm sure somebody has a 993 cup rear for sale somewhere - i've seen them around - if you get a deal on those, and then replace the broken one, you should still come out looking good
p.s. - a repair on that rim will cost about the same as another rim
www.968forums.com
