Threads: 73
On about the middle of the passenger's side of the engine, nestled closely between the oil pan lip and the top part of the engine mount, and very near the exhaust manifold, is a rectangular-like part held to the engine block with various bolts. Either it or the oil pan gasket is leaking oil. Any idea what this part does? I can't find it in PET5 but maybe it's eluding me. The leak here is pretty bad....and I just fixed the crank seal which used to leak. Car runs great but I want to fix this leak before I pull the car off the jacks. Any ideas appreciated. If you've ever pulled this part, it is pretty straight forward? Or do pieces fly all over the garage?
It's behind the housing to which the oil filter screws on.
Harvey
Threads: 73
Here's the picture of the leak area. From what I'm gathering, this may be the lower rear part that contains the balance shaft? Would that be right? It's sure leaking more now that I put Redline synthetic oil in the engine. How difficult is it to plug a leak here? It appears that it's seeping from where the box bolts to the block...or maybe the top of the oil pan gasket. I need to clean it off and spray some flour on it and see if I can pinpoint the leak. I REALLY do not want to pull this part if it's going to be a bear. Has anyone stopped leaks from this area before?
Harvey
Threads: 73
Thanks, Eric,
That's bad news. It looked to be somewhat easy. I'll pinpoint the pricise area of the leak, tweak the bolts, etc and see if I can slow it down. If it's leaking from a bolt (probably not) then I might have a chance. Othewise, it's a project for next summer. I think I might have the seals for that job on hand but looking at the PET, it looks to be one where I might create two problems for every one I fix. Thanks, buddy.
It's a shame that someone hasn't invented some stort of "outside temporary leak patch" for these kinds of leaks. Probably isn't possibe to move the housing out a little bit and squirt in some 574 locktite or something.
Harvey
Threads: 137
That's definitely the balance shaft housing...
Sometimes I've repaired small leaks by cleaning the area REAL good and then applying a 'seal' of that blue ATV silicone sealer. This has helped me slow or stop leaks until I can get around to replacing the gasket.
Keep in mind this doesn't work for coolant under high-pressure...
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 73
Great information! Good ideas! Also, I had just changed to Redline synthetic oil and the leak seemed to pick up intensity. Don't know that I want to go back to a "thicker" oil for this.
Harvey
