way to get RACER X chip
#41
yes i know, i was talking about the <acronym title='wide open throttle'>WOT</acronym> maps in that post, part throttle timing (and fuel) maps will be more tricky to map (also because of lambda regulation )
1992 968 Targa with M030+M220
1989 951 M030 M220
If in doubt, FLAT OUT .
[quote name='netopyer' timestamp='1392756892' post='155241']
guys, remove the ECU and take a photo of it / write down the numbers from ecu "0261 .... " and from the chip and you will know for 100 percent.
if you have 0261200474 on the ecu sticker, you have older Motronic m2.7 ecu not newer M2.10 type (0261203073)[/quote]
In mine, and also mentioned in the DME 'chip' swap DIY of 2005, the correct (new) Motronic # is 0 261 203 070.
which is what most of the cars have. almost all of the "weirdos" are in 92s. i've only seen or heard of 2 early 93s so far with anything other than the "070" unit, including ROW. i suspect those 2 were either leftovers, or possibly changed out at some point by an owner.
Last Post by daly
07-24-2017, 04:29 PM
04-25-2015, 11:56 PM
Last Post by Ernie
05-05-2014, 10:08 AM
04-26-2014, 11:41 AM
Last Post by Ab54666
04-13-2014, 03:22 PM
Last Post by DayDreamer
10-23-2009, 04:44 AM
