Threads: 4
the feeling when you reinvented wheel works like a charm or better than expected, is priceless and worth that time, at least for me ..
it was the same for me when i made my first 200, then 250, and finally 300 crank HP 1900 ccm diesel....
1992 968 Targa with M030+M220
1989 951 M030 M220
If in doubt, FLAT OUT .
Threads: 49
Hi Flash, I have a question about chips.
I recall reading somewhere that the early 92's took a different chip. Mine is a very early 92 cab, I believe the 37th unit made. Does it take a 944S2 chip rather than a 968 chip? Please let me know if you find something that will work in my car when you are done with your cleaning.
Thanks!
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 4
[quote name='Bulti' timestamp='1392754999' post='155236']
MCL, I've read something about that too, and I too worry about the 'normal' chips not working in our cars. Maybe there is a way to find out which chassisnumbers (or enginenumbers) should receive a different kind of chip?
My car was first registered in March 1992.
guys, remove the ECU and take a photo of it / write down the numbers from ecu "0261 .... " and from the chip and you will know for 100 percent.
if you have 0261200474 on the ecu sticker, you have older Motronic m2.7 ecu not newer M2.10 type (0261203073)
1989 951 M030 M220
Threads: 4
are you sure that it does not only differ in chip number? (just asking)
1989 951 M030 M220
Threads: 15
I purchased my car with the Racer-X chip already installed. I can report that it feels quite good paired with the airbox mod. Redline is raised to 7500 rpm (or was it 7800?). In any case, I never push it that far, generally shifting under <acronym title='wide open throttle'>WOT</acronym> around 73-7400 just for safety's sake. Wish we had higher octane gas here in socal.
-Austin
'94 Black/Tan Coupe
Threads: 4
i prepared some file based on my exact stock chip already and i ordered the AFR gauge with sensor, and also my friend is preparing some smart knock detection device and if the weather will be fine, i will start to measure stock AFR, measure it on the dyno with stock software and then finally tune it on road very soon
i definitly agree with flash , that there will be minor difference between any properly tuned file from multiple tuners
there are 2 timing maps which differs from the most found, one is imho for bad gas - it reduces timing by 3,75 degs, and some other one which seems only "moved to right " - not sure what is the purpose of that
also i am looking forward to the results from that high load dyno to see how much performance persisted in engine after that years
1989 951 M030 M220
