Under engine panels
Hi,
I took the sheet metal and the plastic panel off from under the engine a while ago and can't remember how they go back on. Does anyone have a picture?
Steve
Steve Patrick
92 968 Cab
76 912E Coupe
68 912 Targa
68 911 Coupe
78 Alfa Spider
62 Alfa 2600 Cab
Batwing is the first panel to the front, then the plastic square, then the metal one (only '92 models typically). The second plastic one mounts to both the rear 3 bolts of the batwing, as well as to the cross member. The holes only line up a certain way, you'll be able to see how it goes once you get under there. The third panel I don't have since mine is a '95 and so can't be more specific. Good luck.
Rustech
Just go about 10 topics down on this list to the pictures of under car wings. and look at the pictures there.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
08-14-2025, 10:12 PM
06-26-2011, 04:26 PM
12-24-2009, 12:35 PM
Last Post by xrad
04-02-2008, 11:04 AM
