09-27-2009, 05:44 AM
Hello, I am considering upgrading my stock (option 220) LSD to a true race limited slip plate style differential. The car is used for track work and motorkana's.
They seem available in a 40/60, or 50/80 locking percentage. Which one you choose is largely dependent of the combination of your tire size and your horsepower. For example, if you run a really wide tire, but stock horsepower, you apparently want to go with the 40/60. The reason for this is that you don't have enough power to break it loose as you turn, so the car will push and just not rotate enough. If you run stock size rubber on it, you apparently should up it to the 50/80.
As I run stock HP and will keep the rubber basically stock (R spec compound), I think the 50/80 is the go....and would appreciate any input on the two points below.
<b>Advice areas</b>
1: I am open to comments on that ratio, from those with expereince.
2: I am also wondering if it is feasible or makes sense to use a shorter ratio as I have the 6 speed and never use 6th...so am thinking is there an advantage is changing the gearing ratio overall at the same time through the diff ration, and would appreciate advice?
Thanks.
<b>Advice areas</b>
Thanks.
