Threads: 76
Just installed 993 Cup wheels and 225/255 tires. Technical specification booklet says "2.5 bar overpressure" - like that means anything to me <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> (I will admit that I have not actually looked in the manual yet)
Installer, with much Porsche experience, filled with nitrogen to 36psi/44psi. He said that was the recommended level. So far seems a bit high. I ran my 16" 205/225 setup at 36psi and dropped it to 34 if doing a lot of commuting or heading out on the interstate with my lovely wife.
What are others running?
The whole nitrogen thing is a bit weird. I understand the benefits, just hesitant to experiment with lower pressures than I might want due to the hassle of refilling. Or am I missing something?
Ralph
'77 911S (RIP)
Threads: 31
Your gas mileage should be really good at those pressures. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> 44 seems high to me by several pounds. I run my 18s in the low-mid 30's.
(This post was last modified: 04-02-2008, 01:50 PM by
Mark.)
Threads: 59
I have the same wheel and tire combination as you do. I have been running 34 psi in front and 36 psi in the rear. This seems to me to be the optimum for my suspension set up and alignment. I have a stock suspension, Koni adjustables and the alignment is set for a more aggresive turn in than standard. I get about 30K on the rears and about 40 to 45 k on the fronts. and the ride is comfortable. I have run the higher pressures and it makes for a very uncomfortable ride on all but the smoothest roads.
Now, if your thinking about tracking the car or autocrossing then you'd use different pressures.
Chris Vais
2008 Audi A5 Brilliant Black
Threads: 76
And now for the Steven Wright question: Does an air pressure gauge work with nitrogen? <img src="/forum/images/smilies/968/huh.gif" class="smilie" alt="" />
(please don't answer this question that I should have posted yesterday...)
And keep those cards and letters coming kids... I am thinking 36/36 at this point in the conversation.
Ralph
'77 911S (RIP)
Threads: 31
Maybe the reason they are set high is the "lack" of difference between hot/cold tire pressures with Nitrogen fill
Threads: 137
17", standard street driving, manual says 36 psi all four wheels.
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 76
Sounds like the way to go to me.
Ralph
'77 911S (RIP)
Threads: 10
<img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" /> If oxygen molecules 'leak' through the tire, wouldn't you end up with nearly pure nitrogen in the tires? - it just doesn't happen enough to matter. The only benefit I can imagine with nitrogen is lack of moisture. Most racers at the club level don't even bother with nitrogen - too much hassel vs. benefit compared to other things to work on to make a car fast.
If you really want to be Geeky the universal gas law was described by Boyle and Charles. I learned it in high school chemistry as "Boyle's Law - Charles's law (temperature and pressure), but that was a long time ago, in a land far far away. <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
Cheers, Stephen
Stephen G.
Moscow, Idaho
'93 Guards Red coupe, 6-speed, LSD, 17's, chip, strut bar, M030 sways, airbox mod,
