Threads: 45
Hi
yes its the full version of PET with part search and all the V pages, and add on's
it has the very latest updates, last one was last week for parts, and Dec 5th for Prices
some times PET can be a bit hard to follow as it makes no sense, as in the bearing pin
having looked through the entire parts listings for the engine, this is the only part that has a before and after date on it
(This post was last modified: 12-29-2017, 07:47 AM by
Waylander.)
Threads: 45
I am revisiting this thread as a couple of UK fellas are having issues with getting the belt to run in the correct place on the cam pulleys and of course all the rest,
the issue seems to be that the belt is running a bit further back on the cam pulley from the front edge, he sent me a picture, and it looks like from the wear marks that the belt used to run about 2.5mm from the front edge, now it appears to be running about 6mm from the front edge
He has not sent me a picture but says the belt is so close to the numbers on the front of the waterpump its almost polishing them up.
So if there are any educated ideas as to why this is happenng, please enlighten me,
the Pin and the arm have not been replaced, only the O rings
