Threads: 16
I have been looking around for shocks springs and swaybars. MO30 sound good but $$$ is off the wall. Im only 17 and saving money to upgrade my suspension. Koni adjustables will also work. Does anybody know where i can purschase it reasonably?
Thank you,
Alex
1993 Guards Red 968 coupe with 6 speed limited slip
Threads: 35
Well, there's "Reasonable", which for a 968, is "Expensive" for most of us, and there is "Cheap", which, for a 968, doesn't exist!!!
The best Bang for your limited bucks will be the M030 Anti Roll Bar upgrade kit from Sunset Porsche. Factory Parts, and they WILL tighten up your ride. IIRC, I paid $400.00 for the entire front and rear kit, and added a set of rear heim joint adjustable drop links for maybe $50.00... very nice pieces!
Then, the next step is to go for the Koni Adjustable Struts and Rear Adjustable Shocks from Paragon Products, which used to be somewhere in the $1,200.00 bracket, but don't quote me on that... Or buy the components from the Tire Rack for about $800.00 and do the front strut conversion yourself... takes a good drill and a large tube cutter (pipe cutter), or a really steady hand with a Sawzall!!! Measure three times, then measure again before you CUT!!! If you screw up the cut, you are buying a new set of front struts, and there goes your budget for gas to the drive in for the next three years! Oh, I forgot, we don't have Drive In movies anymore!
The next step up is to find a nice set of Bilstein Coilovers, Ledas, or KW's that some Racer bought and decided not to use, or changed out after a couple of track events, but the price goes thru the roof fast with these parts... be thinking $2,000.00 for a minimal setup, used, or $3,000.00 for new, and that won't get you the adjustable Camber Plates either. Might try a Wanted Ad on Rennlist or the PCA web site to see if anyone is selling anything you could make work... and there is always EvilBay...
Best of luck... do the M030 bars first and see what you think... and remember, You are NOT as good a driver as the the car is, so keep your foot OUT of the engine compartment! Yeah, I was 17... once... and I thought I could drive... until I went tail first into a ditch, and had to get hauled out by an old farmer with a Ford Ferguson 9N tractor... His advice was "Brakes work better than the gas pedal on that corner!" He was right!
1994 968 Coupe, Red / Cashmere/Black, 6 spd, [acronym="Limited Slip Differential"]LSD[/acronym], Part Leather, Alpine, Hidden Radar, Airbox Mod, early Engine Decore Panels, more to come!
2002 MB Silver Arrow SL500 AMG Pack, one of 750 imported.
2008 SX4 Sport, 2004 GMC XUV, 1997 Towncar, police pack sleeper.
Threads: 16
lol well the problem is the body roll my suspension is ate up im gettin thrown around in the car like theres no tomorrow. I autocross and i need alot more to improve but i would like the car not to rock like a boat. lol but thanks for the adice.
bad berry are u goin autocrossing sunday? its cool to have another 968 out there.
Alex
(This post was last modified: 05-18-2007, 05:58 PM by
Aro51.)
