Threads: 22
There's a koni yellow suspension setup being offered on RL for a good price (and since I'm in need of at least one strut..), but I don't know if the components will work on the 968 or if they're suited for the car.
Car is a cab, no bracing. To date the car is all stock, and main use will be on the street.
Suspension setup being offered is:
A like-new full set of Koni Yellow shocks and struts (model 8741-1136 Sport front, 8040-1035 Sport rear). These are the single adjustable (for rebound) shocks and struts that are similar to the m474 option. The 8741-1136 are the complete strut housing type. They were replaced by 8641-1038 inserts for non-sealed OE & 8641-1414 inserts for sealed OE units.
Fits all 1987 to 1991 model 944's (including S & S2), all 944 Turbos and 1992 - 1996 model 968. (except w/ optional M030 suspensions)
The front units come with Weltmeister 250-SP sport springs and the rear includes a set of Sway-A-Way PowerBarz 30mm torsion bars.
Will this be suited to my use or are the springs and torsion bars overkill?
-Matt
Threads: 22
I was thinking of a Koni yellow setup on all four corners anyway, but with the drill & cut inserts. I'm not convinced I really need to lower the car or up the spring rate, but the entire setup offered would cost me about the same as new inserts & shocks.
My experience with my car has been fairly limited, but I did find that I had a lot of cowl shake -- would stiffer springs/torsion bars would exacerbate that problem?
-Matt
