Threads: 2
FYI - My car was suffering from a stiff clutch pedal. I just got it back together yesterday, here’s what I learned:
The problem turned out to be the release fork bearings and a badly scored shaft. The shaft had 1mm deep vertical bearing grooves in it.
Also, the Sachs clutch kit comes with the stiffer 911 pressure plate, which I sent back.
I got away with just replacing the disc, fork bearings, shaft, and repacking the TO bearing. If if wasn’t so easy to access, I would have replaced more parts.
Tip:
Insert the driveshaft all the way into the disc plate and make sure the locking clamp bolt will engage before you tighten everything down. You need a little bit of free play in order get the shaft into the end bearing. The driveshaft has a 360 degree groove for the clamping bolt.
1994 968 - currently under construction
1988 944NA - owned for five years
Threads: 15
I'll be replacing my way-too-heavy clutch soon, and hoping for similar results!
-Austin
-Austin
'94 Black/Tan Coupe
Threads: 9
Interested in this, as I have the 964 pressure plate since replacing the clutch, how much does the "real" pressure plate run?
Nacht Blau 968 cab, Wimbledon Green 993 coupe
Threads: 15
I got my 2500 lb. pressure plate, clutch disc, throwout bearing, release shaft and bearings from Pete at RS Barn for around a grand - give him a call for a price breakdown. I'm really looking forward to a properly weighted clutch pedal once the parts are installed. Flash - any weekends looking good for you?
-Austin
'94 Black/Tan Coupe
