Threads: 25
I couldn't find any posts about this and i somehow feel like an invalid, posting whore. for the past week when i would cold start my car it would crank 7-8 times andd then the rpm's would stumble up to it's 900-1000 range. tonight when i started up the car the rpm's shot up to about 1600 and stayed there. What would be causing the problem.. Dirty injectors? DME relay??... I feel like such a novice <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />. I might as well replace everything while i'm in there for the waterpump/belt job ( starting once the parts come in). I also spotted a valve cover leak ( easy fix). The car almost has 60k on it so i assume it's about time for stuff to break.
thanks guys.
94 M030 968 Guards Red/ Beige ~64k miles
2006 F-150 King Ranch 4x4
