Stage 2 & 3 FRP Failure - Symptoms and Solution
Those with stage 2 or 3 D1R superchargers have a special adjustable fuel pressure regulator (FPR) that was part of the kit. Mine failed, and I thought it would be useful to inform others that might have the problem what the symptoms were and what to do.
First the car became difficult to start. I had to hold the pedal to the floor and crank for awhile before it would fire. Once it did start,  I had to keep the throttle open some for a minute or two to keep it from dying .
Second the idle was not steady. It would rise and fall between about 800 and 1200 rpm with the throttle closed.
Third, I had a very weird feeling power dead spot around 2600 rpm.
Fourth, after starting there was a strong gas smell.
Fifth, heavy black soot in the tailpipe.
Sixth, decreased gas mileage.
For my first troubleshooting I changed the idle regulating valve. I watched a number of YouTube videos that described symptoms like mine that were caused by a bad idle regulating valve. This is a pain to change because you have to take the intake manifold off. After changing this valve, I saw no improvement. I wasn't happy.
I checked all vacuum lines and found no leaks.
More research and thinking about the problem led me to the FPR. I hadn't looked at this at first because the pressure on the fuel rail did not seem to be varying.
I pulled the vacuum hose off the FPR in the garage while the car was idling and sure enough there was raw gas coming out. Bingo. FPR with failed diaphragm. I removed the FPR, took it apart and verified the diaphragm was shot. I contacted Bob/Flash, and he was able to point me to the company that had supplied him the FPRs. A search of their website showed they sold replacement diaphragms. I called them, found they do have these diaphragms in stock, and ordered 2. Some days you get lucky because we are down for the count without a working FPR. There were no identifying marks or labels on the FPR that would have allowed me to locate where to get these.
Here is a link to the site page with the replacement diaphragms.  https://www.kirbanperformance.com/replac...tor/p44186
I've attached a picture of my FPR after disassembly. Hopefully there's enough detail to see the sad shape of the rubber diaphragm.
Excellent report, thanks for sharing the info !!
Glad to do it. If this should be in a different forum or subforum. please move it so as many D1R stage 2/3 owners as possible see it.
Quote:Glad to do it. If this should be in a different forum or subforum. please move it so as many D1R stage 2/3 owners as possible see it.
Jay, can you do this ?   There are a couple of D1R SC related threads but can’t remember which ones would be the best for this .  Thanks .
Thanks , i am wondering should i order one , and install a new membrane  ?
Or just wait and see .
volvo V70D5 Black
Porsche 968 amethyst
This is already in "Heavy Breathing" so, I think we're in the right place.
Bob is welcome to answer questions regarding the supercharger or any other D1R modifications.
I’ve been at Watkins Glen for the last 5 days. The last three have been a Zone 1 Club Race. I’ve never seen so many 968’s at a Club Race. They all are participating in the races. They have cool liveries and are of course highly modified. A buddy of mine came to visit with me in his red stock 968. Generally don’t see that many of these babies in on e spot!
Last Post by Chris Vais
04-23-2021, 03:29 PM
Last Post by 94SilverCab
07-23-2014, 09:40 AM
