09-09-2023, 06:04 PM
Been a long time since I've posted, but I'm still a proud 968 owner. After many years I'm still very happy with my supercharger installation. It's been pretty much trouble free and is a great performer. Earlier this summer the engine became very hard to start, and the only way it would start was with the throttle wide open. It then took some fancy footwork to keep it running until it warmed up a bit. Symptoms matched a bad idle regulating valve (I watched a bunch of YouTube videos to learn this.) I changed the idle regulating valve (a real PITA to do) with no improvement. Checked all vacuum lines carefully, and they all seemed good. Initially I discounted a problem with the fuel pressure regulating valve because the pressure on the rail was right at 50psi and hardly changed if I revved it a bit. Other symptoms though made me suspicious such as terrible fuel mileage, black soot in the tailpipe and a fuel smell that hung around after starting. After some YouTube videos on this topic, I tried pulling the vacuum hose off this FPR in the garage and low and behold raw gas came out.
So I've got a D1R Stage 3 supercharger FPR valve with a torn diaphragm. Has anyone else had to replace theirs? Can you point me to a make and model and source? I did a search on this site and the internet in general and couldn't find anything. Thanks
