11-27-2011, 05:25 PM
From what I've read on this site and others, Bosch ICV issues are not uncommon:
[color="#225985"][color="#225985"]Car won't idle[/color] [size="2"][color="#a4a4a4"]in[/color] [/size][size="2"][color="#777777"]Engine[/color][/size][size="2"][color="#777777"] - solution was to replace [/color][/size][/color]
[color="#225985"]Idle Control Valve[/color][size="2"][color="#a4a4a4"]in[/color] [/size][size="2"][color="#777777"]Electrical Gremlins[/color][/size][size="2"][color="#777777"] [/color][/size]
[color="#225985"]idle control valve[/color][size="2"][color="#a4a4a4"]in[/color] [/size][size="2"][color="#777777"]What is that noise?[/color][/size][size="2"][color="#777777"] [/color][/size]
[color="#225985"]Idle Control Valve R&R and cleaning[/color][size="2"][color="#a4a4a4"]in[/color] [/size][size="2"][color="#777777"]Engine & Drivetrain[/color][/size][size="2"][color="#777777"] [/color][/size]
They go by many names, idle air control (iac) valve, idle speed regulator, idle speed actuator, idle control valve... The failures are not unique to Bosch, but the price of the replacement part is. I suspect timing, valve health and air filters play a role in thier longevity and cleanliness.
I would benefit from a good vacuum leak test procedure for this car (hint, hint). I'm familiar with the carb cleaner method and gauge test. That would be a great write up since idle and cold start problems on these cars seem common. What are the most common leaks?
