Threads: 45
The simple answer is yes they do, I have seen pictures of a 968 tank sucked almost flat due to blocked breathers
The charcoal canister has foam, and gauze separating the charcoal from the pipes, over time the foam and filter gauze break down and the charcoal drains through and fills the pipe from the rear to the canister, this pipe is not part of the normal fuel lines
It runs under the drivers side floor and is plastic
Threads: 45
I would suggest jacking it up drivers side, popping out the arch liner, you can then see the canister, disconnect it and check the pipe back to the tank, you should be able to blow through it, and give the canister a shake, if bits fall out, you need a new one
If you ant and need to replace the line its not expensive but its a real challenge to get done
Coupe 944 201 737 01 $37
(This post was last modified: 07-22-2021, 06:07 PM by
Waylander.)
Threads: 45
Thats correct,
But it does breath in as well as out
(This post was last modified: 07-28-2021, 06:10 AM by
Waylander.)
Threads: 13
That shut off valve is near the booster from the brakes.
In the enginebay on the driverside at the top of the innerfender
Threads: 45
Yes and its also vacuum controlled
