RS Barn VS OEM Flywheel
Hi,
Since I am going to replace all the parts operating the clutch, I was thinking of replacing the DMF as well.I am not sure it is broken, I just want to be on the safe side. I had a look on the RS Barn web-site and the weight saving compared to OEM Flywheel is hugh.
But, how will the RS Barn flywheel perform on a stock/street car? any experiences?? will it affect the overall smoothness of the car/ ride etc?
Regards,
Rutger
1992 Amazon green convertible. Cargraphic cat. back exhaust, RS Barn/ Design 1 Racing lower & upper strut brace, RS Barn stage 1 Chip, Airbox modification, M030 Swaybars.
It all depends on how you drive the car. It appears that the lightweight flywheels are not recommended for cars which are regularly driven in heavy traffic. There are a few poeple on this site who have aluminum flywheels, and I'm soon they'll chime in soon.
One exciting new development is that Flash is nearing completion of a spring-centered clutch disk, which will significantly reduce the transmission noise associated with conversion to a single-mass, lightweight flywheel. I don't know if his disk will work with the RS Barn flywheel, or just with the Fidanza, though. If it would work with the RS Barn, which is a few pounds heavier than the Fidanza (though it costs a few hundred dollars more), this seems like it would be an attractive solution for many people.
It is excruciatingly expensive to take any substantial amount of weight off this (or any) car, and imho, the availability of a flywheel that will signicantly reduce the rotating mass is an attractive opportunity, if you are willing to give up a bit of driveability, or if your car is primarily used in light traffic. Good luck with the decision either way.
I have the RS barn flywheel and I haven't had an issue with driving in traffic. The car is a bit more stuttery when you're trying to decelerate gently, and of course there is the drive train chatter that goes along with it. I found that with this flywheel the car has more urgency to get going compared to the stock DMF. Not much, but you'll feel it.
Overall I think it's worth getting while-you're-in-there type of thing... if you don't mind a bit of noise <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
-Ren
it will work with the rs barn flywheel - in fact, it was developed specifically for that flywheel, not the fidanza - i am pretty sure that it will work with the fidanza though
[quote name='flash' post='45009' date='Dec 24 2007, 11:12 PM']it will work with the rs barn flywheel - in fact, it was developed specifically for that flywheel, not the fidanza - i am pretty sure that it will work with the fidanza though[/quote]
Cool! I'm sure there will be a lot of buyers. In fact, that occasional judder I feel suddenly seems to be getting worse... <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
A "belt and suspender" question -- well two questions...
If it's time to sell the car and silence is a must, could we use the spring loaded disk with a DMF?
Leading to ask... why not use the spring loaded disk with a DMF. Save wear and tear on the expensive DMF. A Porsche clutch that will last a million miles?
1993 Black coupe @ 100K
LWFW + Chip
M030 Sway bars with Delrin from RSBarn
Southboro, MA
[quote name='Georges' post='45066' date='Dec 27 2007, 12:26 PM']A "belt and suspender" question -- well two questions...
Leading to ask... why not use the spring loaded disk with a DMF. Save wear and tear on the expensive DMF. A Porsche clutch that will last a million miles?[/quote]
The standard original setup is a spring clutch and a DMF..
the 968 OEM setup is NOT a spring clutch - it is a solid center clutch disk, with no springs
the new spring center clutch disk will NOT work with the DMF
however, there will soon be an improved OEM style disk available too, but it will not have springs
Flash,
You never cease to amaze me, I want to know where you are getting all the energy for this? Keep up the good work! I look forward to the improvements in the clutch/flywheel since I am due to have mine replaced.
I think we're gonna need a spread sheet listing what items can be used with what <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
-Ren
energy? - nope - just too dumb to know any better
spread sheet - i think there will have to be something, but it's pretty easy to just call pete too
I'll have to see where my budget sits once my clutch finally gives it up, its slipping now. I don't think I'll be able to swing the LWFW with a new clutch though <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
'92 968 ~ Amazon Green Coupe, 6spd, LSD
[quote name='Apex Rex' post='45112' date='Dec 29 2007, 10:09 PM']I'll have to see where my budget sits once my clutch finally gives it up, its slipping now. I don't think I'll be able to swing the LWFW with a new clutch though <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />[/quote]
How many miles are on your car? If the clutch is slipping, there's a fair chance the surface of your flywheel is compromised. This means you'll have to take it out to resurface it, at which time they can check to see if the rubber isolation piece is in good shape. I understand it's difficult, if not impossible in many cases, to rebuild a DMF, so it may be more economical in the long run to go ahead and replace it with a single-mass flywheel.
[quote name='flash' post='45009' date='Dec 25 2007, 06:12 AM']it will work with the rs barn flywheel - in fact, it was developed specifically for that flywheel, not the fidanza - i am pretty sure that it will work with the fidanza though[/quote]
Flash,
Currently, I have a Spec FW with a Sachs clutch kit, and, obviously, I have the noise and rattle problem in the transmission, especially in 1st, 2nd and 3rd gear.
I don't know if the Spec FW is the same as the Fidanza one, but they look like the same.
Anyway I hope that your clutch disk will work too... <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" />
[Image: IMG_2813.JPG]
[Image: IMG_2815.JPG]
Porsche 968 CS M030 Iris Blue Pearl
it might - won't really know without putting it together, but from the photos, i think it will
looked at it again - there might be a couple of problems - have to take some measurements to know for sure - tough to see from the shots
the outside diameter of the pilot bearing flange may be too large and interfere with the back of the disk
the "dish" of the front face is the big question - how far down the bolt surface is relative to the friction surface will determine whether or not the bolt heads hit anything
[quote name='flash' post='45506' date='Jan 10 2008, 04:49 PM']the "dish" of the front face is the big question - how far down the bolt surface is relative to the friction surface will determine whether or not the bolt heads hit anything[/quote]
It should be something like 0.2 inch (5-6 mm)... if I remember... <img src="/forum/images/smilies/968/mellow.gif" class="smilie" alt="" />
Edit: I misunderstood the message of flash, sorry.
i have a powerhaus billet flywheel in my car. Its lighter then all the other flywheels avail @ 12.5LBS
pretty sure the powerhouse is the fidanza, same as i have
05-05-2011, 02:17 AM
04-06-2011, 12:02 PM
Last Post by firefish
08-28-2009, 02:01 PM
08-19-2009, 01:22 PM
04-08-2008, 09:53 AM
Last Post by Anchorman
09-05-2007, 11:05 PM
